Hello everyone, my name is Lucian and I live in North Italy. The last autumn I started to install a AC system on my 2.0 ABK '94 Audi 89 cabrio.
To be short, I have one last wire which I cannot understand where is going. On the wiring diagram it goes on the "ELECTRONIC THERMO SWITCH", but I cannot understand what is that. That wore is passing through the 5 pin red connector, and is arrive in the F14/G2 .....sensor/switch/....or what that means.
The AC sistem is working, the air is cold, the compressor is turning off when the pressure is too high... everything seems to be fine.
But I know that I left that wire "BLUE/WHITE" free and this is not normal.
I think that his function is to turn off the compressor when the 2 velocity off the fan is active (too keep the idle off the engine when the power consumption is higher).
This is only my supposition....
If anyone can help me with the destination of that wiring, it will be great.
Thanks all for attention.
