Hello!
I have little problem with my Audi 80 ABK from 1993. In idle state on
warm engine it has between 950 and 1100 RPM. When I press clutch engine
speed drops to 1100 RPM and then slowly drops to 950 RPM. I suppose, it
is nothing good.
So... I decided to check TPS with voltmeter. I messured resistance and voltage.
Measurements:
1). Resistance (ignition OFF):
- 1 and 2 pin - Closed throttle: 1.35 kOhm. While opening it suddenly
drops from 1.35 to 1.20 and then increases linearly from 1.20 to 2.53
kOhm (full opening of throttle),
- 1 and 3 pin - 1.91 kOhm,
- 2 and 3 pin - Closed throttle: 3.10 kOhm, decreases to 1.35 kOhm (full opening),
Correct values?
2). Voltage (ignition ON - engine OFF):
- measured on 2 pin - Closed throttle: 0.65V and increases linearly to 4.20V (full opening)
Correct values?
Someone in polish forum told me that 0.65V isn't correct value and I
have to adjust TPS. In ABK produced after 1994 it's done with VAG, but
before 1994 (like mine) with voltmeter. I have no idea how to do that
and what voltage should be.
Any help?
Thanks for your time.
Greetings from Poland,
Rafal
PS. Sorry for my english.
